Message 1 of 17
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Team
I am wonder if you could change the project color when I work on two more projects at the same time.
For example, I open a central file and local file at the same time they are the same project. I can only identify both project by reading their name. But sometimes I will accidently work on the local file and not save in the central file which I will double up my works.
If you could introduce a function to change the tab view color when I open another file, it would be much helpful.
Thank you
Sam
