Hi, @aadamsA2F2Z, the only thing you have to do is work only in the specific floor plan of the level you want to change. There is no reason for this to make changes in the other levles, unless you previously grouped and make multiple copies or constrained elements among levels. Verify if your walls and rest of elements are constrainted within the levels you want to modify. I.g., if you modelled a wall troughout all building levels, obviously if you move it will move in all floor plans; to prevent this behavior you must constraint from base level to top level within the desired level and above, and same to each level. If this won't works, please give more information in order to help you better.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
