Hello!
I have a component imported into a custom family, and I would like the component to change its type as I change Host family type. Is it possible? If it is, then how?
Thank you!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Do you mean you want the nested Family to change its type when you change the type of the parent?
edit your family > family category and parameters > and change? thanks
You can associate instance parameters from the shared nested child to any type of parameter in the Parent.
However, the label I mentioned above is the whole nested child...ie:
