Change family parameter using project parameter
deepesh_wig
Message 1 of 22
deepesh_wig
I have several hundred equipment models which may be (dependant on the Client preference) 'Client supplied'. I have a shared yes/no parameter named 'Client Supply' (applicable to speciality equipment only) which I use to sort the equipment schedule into Contractor supplied equipment and Client supplied items.
My question here is: Can I somehow use the 'Client Supply' yes/no project parameter to change the family parameter 'Manufacturer' to "Client supply" when yes and leave as filled when no?
Thanks for any advice.
Deepesh
Replies (21)
Message 2 of 22
Seeing the volume of equipment models I would suggest to have a go at Dynamo. Dynamo is great for these purposes to get information from models and create links between parameters where Revit cannot do that. Keep in mind that the link only exists in Dynamo and that if you update information, you will have to rerun the script to rewrite the information.
Message 3 of 22
I think you're talking about changing the actual text value entered for the Manufacturer Parameter. That Manufacturer Parameter is a TYPE Parameter. Sounds like you need an Instance Parameter.  But, I don't see why can't control with an if statement (e.g. if(Client Checked, "Client Supplied", "Acme")).
Message 4 of 22
deepesh_wig
@barthbradley, I can - just that I will need to type a variant on the formula over 400 times.
Message 5 of 22
400 variants?! You only named 2 conditions: Client Supplied and Not Client Supplied (meaning you decide the Manufacturer and/or Subcontractor). Aren't these project driven? If so, you can do all this work with little effort through Schedules. No?
Message 6 of 22
deepesh_wig
@barthbradley, 400 families in my library that need to be 'Client supplied' or 'Contractor supplied' depending on which pocket the client wants to take the money out of Smiley Happy
Message 7 of 22
You can pull that information into a schedule and change it there. I mean it's the same thing with Cost Parameter. We don't go to every one of our families and update costs as they change.
Message 8 of 22
I don't get the goal of this exercise. The same chair can be supplied by a Client or by a Contractor, it doesn't make the chair family any different. Properties like this should be under projects, not families.
Message 9 of 22
deepesh_wig
@ToanDN, Your are correct that the chair family does not change. However (using my current project as an example), the client may want to shift 2 fridges from an existing site [Client supply] and want 3 more of exactly the same type supplied by the contractor. I need to list all 5 because services for all need to be supplied and there are costs involved in 'pick-up and install' which are different from 'supply and install'. I can certainly amend the family on the fly and add a 'client supply' type (which I have done for this project) - I was just hoping to build a simpler, one-click solution for future projects.
Message 10 of 22
Add the paramaters in project environment and you can change the value via instance properties or a schedule. There is no reason to mess with the families.
Message 11 of 22
@deepesh_wig: here's where I'm getting confused. You're identifying the deliverables based on the project, not based on the family; right? I mean, you only have one fridge, but that fridge may be included in contract in one project and not included in contract for another.  Do I have the gist of it right?
Message 12 of 22
deepesh_wig
@barthbradley@ToanDN:
Consider K61/C15 or K62/C16. Exactly the same object (same family) but the Manufacturer, model and comments are different. I can make a 'client supply' type within each family but am trying to avoid having to go through over 400 families doing so.
Message 13 of 22
Bro... nobody has suggested you to mess with the families.  I said clearly that create the parameters in the project.
Message 14 of 22
Ditto.
@deepesh_wig: Maybe this will help you embrace the concept:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Message 15 of 22
deepesh_wig
@barthbradley@ToanDN: Thank you. I believe you and I are on completely different tracks (perhaps I haven't been very clear in stating the problem). Never mind. Moving along.
Message 16 of 22
Sorry we couldn't help you @deepesh_wig. Perhaps we don't get, and your situation is truly unique. But, I have been at this a very long time and I have never seen a situation that necessitated opening and modifying hundreds of families.  I'd love to hear about one though.  Always learning.
Good luck to you.
Message 17 of 22
@deepesh_wig
Below is an example of a schedule with three exactly pieces of a desk, same family same type, with different manufacturer information.
Message 18 of 22
deepesh_wig
@ToanDN, as I mentioned previously: I have over 400 families with data already filled in the Manufacturer Parameter. I was trying to figure out how to amend that data based on a yes/no parameter named 'Client Supply' so that I don't have to re-work 400+ families. Adding a new parameter will still be re-work.
Message 19 of 22
Thing is the Manufacturer parameter is a built-in Type parameter so you cannot change some instances of a Type without affecting the rest.  Maybe you should just duplicate Type, keep the Manufacturer for the new Type blank, then swap the Client supplied instances with this new Type.
Or if you only need a "paper" solution, create conditional format to black-out the cells.
Message 20 of 22
@deepesh_wig! A parameter is a container for information  -- that's all! Makes no difference where you input that information, but opening up 400 families to do it 400 times is insane!
Sorry for the outburst. Must be my nap time. Smiley Wink
