Change demensions af a family loaded in a project
I want to change the demensions of a family loaded in the project. I made the family myself, demensions of the family are 'types' but when the family is loaded in to my project i can't change the dementions in the 'properties', see image below with the read circles. The dementions in the properties pannel ar grey en there is only an 'volume' demention. What am i doing wrong?
TripleM-Dev.net
The properties you see when selecting a element are the instance properties.
Click on Edit type, here the type properties can be edited. (this happend then for all those types!)
Structure of elements:  Family -> Type -> instance! (where instance are the actually placed objects)
alan_eu
This volume parameter is a system parameter as you can find area for some other stuff...
By the way, you could create your own volume formula with parameters calculated by width*height*lenght.
So when you find those parameter inside edit type, the volume will update by himself.
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
