Proper way to draw an inregular shape wall
3 ANTWORTEN 3
Nachricht 1 von 4
HeadbuttJ
302 Aufrufe, 3 Antworten
What is the proper way to draw an irregular shape wall as below?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: HeadbuttJ
Several ways:
- edit profile of a wall and draw the shape
- split face a regular wall to create the shaoe and paint with a material
- create parts from a wall and divide parts to create the shape and change
material
Nachricht 3 von 4
There is nothing irregular about that wall.  The wall's finishing materials are different from the walls next to it.  One fast and easy approach would be to use the Split Face and Paint Tools.
  Revit 2018 – The Split Face and Paint Tool – Cadline Community
Nachricht 4 von 4
alan_eu
I prefer to use the @barthbradley @ToanDN solutions, but there´s one more good way to do this: using parts! Once you master this technic you will always be tempted to find solutions using it...
I´m a parts fan :grinsendes_Gesicht_mit_lächelnden_Augen:
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
