Change cut plane height in plan view in family editor
craig
craig
How do you change the cut plane height in plan view in the family editor?
EATREVITPOOPCAD
Select the view & change the view range properties
The definition of insanity is doing the same thing over and over again and expecting different results
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-C...
Change the Default Sill Height of the Window in the Project.   Default Sill Height is a Type Parameter.
Switch from Family properties to View properties from this dropdown.
It's an interesting question - one that makes me wonder what you are trying to accomplish.
Maybe you are just trying to remove all the bullsh*t from the View.  Maybe all you really need to know is that you can toggle Preview Display on and off.
