Change cut pattern scale
cbt990
cbt990
I would like to adjust the scale of multiple cut patterns across several views that share a view template.
Is there a way to adjust the cut pattern scale in VT?
Revit is amazing
jvpantin2
What do you mean exactly? How about this?
https://forums.autodesk.com/t5/revit-architecture-forum/how-to-scale-a-loaded-in-section-detail/m-p/...
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
You have to change one by one for each category and each view template.  Why don't you change the cut pattern definition in the materials instead?
