Change color of walls in one sheet only
HEVNBND
Message 1 of 12
HEVNBND
I created a Duplicate View. Then I went to Edit Visibility/Graphics under properties for that new view. When I change the wall colors it changes them for all other sheets as well. How do I just change the colors on this one duplicate view? Thanks
Replies (11)
Message 2 of 12
You must have "Duplicated as Dependent" so they are the same views.  Right click the view you want to change and make it an Independent View.  Then when you modify the Visibility Graphics it will apply to that one view only.
Message 3 of 12
HEVNBND
Nope I did Duplicate. When I right click it the Floor Plan under Views "Convert to independent view" is greyed out.
Message 4 of 12
What did you change? Cut line, cut pattern, projection line, surface pattern?
Message 5 of 12
HEVNBND
Line Color
Message 6 of 12
Can you show a screenshot of the V/G overrides window where it was changed?
Message 7 of 12
HEVNBND
Message 8 of 12
Just as I expected, you are changing Object Styles, which caries through the project, not just one View. Undo it, and change the walls category color by open that view,  type in VG to open the VG window, and change directly there, under Model tab > Walls.  Do not click Object Styles button.
Message 9 of 12
Object Styles will change lines for the entire project.  Change just under Model Categories or Annotation Categories.
Message 10 of 12
Object Styles... was clicked under Visibility Graphics
Message 11 of 12
HEVNBND
After I press VG on the view i am wanting to change everything is greyed out under the Model Categories.
Message 12 of 12
The view got a template assigned to it. Look at the view properties and change View template to None.
