No "Model" type patterns found
I have no Idea what is causing this pattern to be unreadable, but could someone please help. I am trying to construct a wall tile pattern and I think it is relatively simple.
Here is the pat and attached is a sketch
;%UNITS=INCH
;%VERSION=3.0
*ELWTP, Staggered
;%TYPE=MODEL
0, 0, 0, 0, 120
0, 0, 72, 0, 120
90, 0, 0, 32, 0, 72, -48
90, 0, 72, 24, 0, 48, -72
I am not sure why it keeps trying to upload sidewaysI am not sure why it keeps trying to upload sideways
Cheated...
;%UNITS=INCH
*ELWTP,exported by pyRevit
;%TYPE=MODEL
180, 192, 0, 0, 96, 192, 0
90, 0, 0, 0, 192, 96, 0
90, 72, 0, 0, 192, 96, 0
90, 192, 0, 0, 192, 96, 0
180, 72, 24, 0, 96, 72, -120
180, 72, 48, 0, 96, 72, -120
180, 72, 72, 0, 96, 72, -120
180, 72, 96, 0, 96, 72, -120
180, 192, 32, 0, 96, 120, -72
180, 192, 64, 0, 96, 120, -72
180, 192, 96, 0, 96, 192, 0
I bet it would work if you delete ";%version=3.0".
Could be wrong.  But  ";%type=model" couldn't hurt.
oops. I just saw it has ";%type=model"
What about also putting "*ELWTP, Staggered" above everything else.
how did you cheat, @Anonymous?  Did you already have ELWTP?
hugha
I also cheated in creating this pattern containing two unbroken lines (the verticals) and two broken lines (the  horizontals) for a total of four elements as opposed to 10.
;        Written by HatchKit Team Edition
;        HatchKit Team Edition (c)1990-2019 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 2019-03-15
;-Time                                   : 12:39:19
;-HatchKit Team Edition Version          : 3.1.11.2776
;%VERSION=3.0
;%UNITS=INCH
*elwtp,from HatchKit
;%TYPE=MODEL
90,192,0,0,192
90,72,0,0,192
0,0,24,0,-24,72,-120
0,72,32,0,-32,120,-72
Edit: OP was so close - as flipping the posted dX and dY values for the broken lines as shown below yields the desired pattern.
Note that a zero dY  (offset normal to  the line segment) will render the pattern completely undrawable so any such pattern does not load - instead emitting that cryptic  all-purpose error message.
;%UNITS=INCH
;%VERSION=3.0
*ELWTP, Staggered
;%TYPE=MODEL
0, 0, 0, 0, 120
0, 0, 72, 0, 120
90, 0, 0, 0, 32, 72, -48
90, 0, 72, 0, 24, 48, -72
hope this helps,
Hugh Adamson
It was setting dy equal to zero was the probelm! I had forgotten that numbers 3 and 4 are displacement direction and distance and I was treating it like x2 and y2. Thank you so much!
This was the final solution is anyone was curious:
;%UNITS=INCH
;%VERSION=3.0
*ELWTP, Stacked
;%TYPE=MODEL
0, 0, 0, 90, 120
0, 0, 72, 90, 120
