I created a Duplicate View. Then I went to Edit Visibility/Graphics under properties for that new view. When I change the wall colors it changes them for all other sheets as well. How do I just change the colors on this one duplicate view? Thanks
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You must have "Duplicated as Dependent" so they are the same views. Right click the view you want to change and make it an Independent View. Then when you modify the Visibility Graphics it will apply to that one view only.
Nope I did Duplicate. When I right click it the Floor Plan under Views "Convert to independent view" is greyed out.
Just as I expected, you are changing Object Styles, which caries through the project, not just one View. Undo it, and change the walls category color by open that view, type in VG to open the VG window, and change directly there, under Model tab > Walls. Do not click Object Styles button.
Object Styles will change lines for the entire project. Change just under Model Categories or Annotation Categories.
After I press VG on the view i am wanting to change everything is greyed out under the Model Categories.
