Change color of Split Face boundary?
5 REPLIES 5
bill_gilliss
1343 Views, 5 Replies
I would like to make the face boundaries displayed when using the Split Face tool much more visible, maybe changing them from yellowish to a saturated orange. But I don't see anywhere to do this, not in V/G, not in Object Styles. Is this hard-coded, or is is something I can adjust? Thanks.
5 REPLIES 5
in reply to: bill_gilliss
Override Graphics in View: By Element. Projection Line.
FWIW: this will affect the host projection line as well.
Redrunner92
Use the Line Weights tool.
Redrunner92
Or do you mean this? If so, I don't believe you can change that. It would likely be in the "Revit-wide" Options menu if you could.
bill_gilliss
in reply to: Redrunner92
Yes - that the one I meant - the edge of the host object. Thanks.
Redrunner92
Yeah, sorry my answer wasn't what you wanted. Sometimes along with you, I also wish I could change the colors of sketch boundaries and other built-in lines.
