- Mute
- Permalink
- Report
The Most Simple Gable (Revit File Attached)
The reference roof pictured below looks pretty simple. I was thinking I could model this in no more than 5 minutes.
It took me an hour and 15 minutes.
I've got 3 roofs: the main roof with a 1' overhand over the main footprint, and two gables. The gable on the right over the garage is no problem; a simple join. However, the gable on the left is what caused the slowdown.
Notice how the fascia board is flush all the way around and up the gable:
The main slope is a 5/12 and the gable is 9/12. Notice how the gable join at the corner of the main roof (left green circle).
Roof Dim's
I had to (despisingly) attach the wall below the gable using an edited profile and not the attach roof tool due to a roof join error.
The inside roof geometry is relatively accurate:
What is the best procedure to model this in the future? How long should this take a Revit modeler? How long does it take you?
