Chain link fabric gate family
linkboy
Message 1 of 13
linkboy
I have a gate with chain link fabric. Gate is a family. But I can't get anything inside the family environment to represent the transparent chain link(arrow pointed) in shade mode or hidden line mode. For now the chain link is a view specific override. Thanks for look up.
Accepted solutions (4)
Replies (12)
Message 2 of 13
syman2000
Have you check out the material and type in the word chain?
Message 3 of 13
Like this?
No Transparency:
Message 4 of 13
linkboy
This is nice in realistic mode. I try to use it for CD as part of the elevation. Elevation is hidden line mode or shaded mode. Unless I miss something here, the chain link material wont show transparent in either hidden line mode or shaded mode. Below is the image I applied fence material to a extrusion block in the door family. One shows "correctly" as see-thru one is blocked.
Message 5 of 13
Did you see my post?
Message 6 of 13
linkboy
Adjustment is view specific. Other people working on their view happen to have the gate, unless they overwrite the element property. The gate is going to be block component behind. If this can be incorporated into one family, no special setting /tweak needed for view specific.
Message 7 of 13
Creating a Rule-Based Filter and adding it to the View is not an option?
...the other option would be to MODEL the Chain Link.  Yes, I know: seriously ridiculous.
Message 8 of 13
Create a view filter for it.
or use a 3D elevation instead.
Message 9 of 13
linkboy
yes, I saw your response.  Thanks ! Adjustment made for element is view specific. Looking for something can be done in family level, so no need making change for each view.
Message 10 of 13
Model it then. Maybe with a Curtain Wall.
Message 11 of 13
linkboy
I tried that. Only issue is I have to send message to other team members (they are off-site) to ask them load filter and apply it. if they forgot to do it, their view is getting something blocked. thanks for chip in.
Message 12 of 13
Add the filter to all elevation/section view templates.
Message 13 of 13
syman2000
If you want to built into the family, you may want add a shared family nested into the gate.
There in the filter, you can set the family to display as transparent
