Certain levels are not an option for an underlay
ashleyb
Observer Observer
Message 1 of 17
ashleyb
Observer
Observer
I am working on a project where I have structural plans (walls plans) and floor plans (joists plans). I am trying to underlay the wall plan below so I can line up my studs from level to level.
These structural plan levels are labelled as 01A-1st floor walls, 02A-2nd floor walls etc. My floor plans are labelled as 01-1st floor, 02-2nd floor etc.
As you can see in the attached when I try to choose an underlay level the wall levels are not an option to choose. They used to show up and now for some reason they are not there and I can not figure out why. I have compared settings with other projects and they all seem to be the same.
Replies (16)
Message 2 of 17
Are they Duplicate View of the same Level?
Message 3 of 17
ashleyb
Observer
Observer
No, all of the levels were created new. I duplicated the plans as a dependant but never duplicated the levels.
Message 4 of 17
When you go to View=>Plan View=>Floor Plan=>uncheck do not duplicate view,  you see all those levels you are speaking about?
...What does their Properties say is the Associated Level?
Message 5 of 17
ashleyb
Observer
Observer
Yes, I can see all of those levels in there.
Message 6 of 17
JasonKunkel
Do you have plan views for the levels that are not showing up in the Underlay dropdown? Levels with no associated plans cannot be underlayed.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
LinkedIn
Message 7 of 17
....and the Associated Level?
Message 8 of 17
Ya know that Floor Plan Names are not Levels right?  They are created based on the level...
Else we would have a giant mess of levels to try to filter out on the elevations.
Sounds like you just need to temporarily turn on certain categories in your view and change the overlay.
Message 9 of 17
ashleyb
Observer
Observer
I do have plan views for all of these levels.
Message 10 of 17
ashleyb
Observer
Observer
I can see the Associated levels in there.
Message 11 of 17
cbcarch
-Try setting the View Template to None.
-Also, check Discipline of the Structural Plan Views--default is Structural, perhaps try changing to Architectural or Coordination.
- Check View Range of the Struct. Views to make sure cut plane/view depth is set correctly so underlay of lower level/level below could be visible.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 12 of 17
davidneo1988
yes they are in my case. what does this mean?
Message 13 of 17
What are "they"?  What is "this"?
Message 14 of 17
davidneo1988
I was replying to barth. He sent a photo that concludes my situation. I would like to know the fix for this. My underlay range is unavailable and my view plan is duplicated but not dependent. Any thoughts?
Message 15 of 17
Only levels with plan views can be shown as Underlay.  If you only added the levels, then go ahead and create plan views associated with those levels.
Message 16 of 17
davidneo1988
apparently this was just another revit fluke. decided randomly to come back
Message 17 of 17
RDAOU
Nope no flukes there...Just Underlay rules.
  1. For a Level Datum to be available as an underlay, it must have at least ONE plan view
  2. What becomes available on the Underlay drop down menu is the Level Datum itself (ie: Not the plan views created for that Level/Building Story)
  3. If for instance a Level has 100 floor plan views (ie: duplicate views), it would still be listed as ONE single LEVEL on the Underlay drop down menu (ie: Not 100 floor plans)
