Central Files and Shared Coordinates
We have a problem with our Revit file which is set up as a Central Model. Our file has links to four other Revit files from four other consultants. The main consultant, the architect, also sets up a separate Revit file for the Site Central Coordinates. So in total, our Revit file has 5 Revit links, which are downloaded on our server. Everything was working well until today. The architect sent over their uploaded Revit file, which we then loaded into our Central model. The Site Coordinates Revit file did not change. However, after uploading the new file from the architect, all of our information on our model appears to have shifted, by about 300mm. All of the Revit links are loaded as Overlays. We have tried reloading the Site Coordinates Revit file, and the Architect's file, but the issue does not change.... all of our information is in the wrong place! Is there something we need to do to the Central model file to correct this?
Thanks in advance.
Peter
I forgot to add: we are using Revit 2019.
SteveKStafford
Have you asked them if they moved the building(s)?
Steve Stafford
Orsolya.Balazs
Autodesk Support
Autodesk Support
Hi Peter,
It sounds to be reasonable to check what was changed, in term of coordinates, in the architectural model like @SteveKStafford recommended- considering that before the coordinates were correct.  Please give a feedback if this cannot be clarified and if you can provide the files we can get a closer look on it.
Orsolya Balazs
Product Support Analyst - AEC
