Ceiling Plan
Ceiling Plan
Message 1 of 27
Ceiling Plan
Hi, I am using Revit 2017 and created a three-story structure.  I applied a 2 x 2 ACT ceiling but cannot see it.  I cannot even select it within the ceiling plan view.  I can see it in 3D view and select it there.  Any help would be greatly appreciated.  I am very new to Revit.
Replies (26)
Message 21 of 27
Yep. Ceiling is at 7'-4", view range must be lower than that, not 7'-6".
Message 22 of 27
To what?
Message 23 of 27
Sorry, I am really new to Revit and am still learning how to use it.
Message 24 of 27
if you still don't see it, then check the tile material and make sure it has a surface pattern assigned.
..7 as in 7'-0"
Message 25 of 27
My ceiling height is 8'6"
what should I set my view range to be then?
Message 26 of 27
Your ceiling height is at 7'-4" per your screenshot, not 8'-6".  Change the view range cut plane to something lower than 7'-4".
Message 27 of 27
think about it @Anonymous: you are standing in the middle of the room looking up. Say you're 8'0" tall -- how would you see a ceiling if it is 7'6" from the floor? It's below you then; not above you. Get it?
