I'm trying to help a client who's using Revit 2017. To bring in their luminaire schedule they type it up in Excel, link that into CAD, then link the dwg into Revit. This method has worked fine for them in the past, using Revit versions 2015 and 2017. However, when they updated to 2017.2 the text gets jumbled (see screen shots below - the first one is prior to upgrading and the second one is with 2017.2). Any thoughts on what would cause this or how to fix it?
see this post, maybe It could be related
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2017-text-upgrade-issue/td-p/6373019
Hi @Anonymous
Is this issue specific to one user/ particular machine?
Which versions of windows are you using? Can you also specify which graphics card you use?
Are you using remote printing services?
Which PDf printer are you using? If it's Microsoft PDF, try using cute PDF or Bullzip PDF maker and see how it prints.
Looking forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
