This is a question from the other side of the fence - I'm from an MEP firm and am working on finding a solid method of coordinating ceilings and grids. The issue is that we (the electrical engineers) primarily control the layout of the grids through our lighting design while the architect controls the Ceiling Types. So currently, we recreate the ceilings in our model (or copy them over) and then we have Ceiling-Based families (as opposed to face-based) for our other electrical devices (i.e. Fire Alarm) that will follow the ceiling Grid as we adjust it.
It is a little bit of a pain to keep up this coordination, but it makes it so much better for us to have and control the ceiling grids. Does anyone here work with engineers who design the lighting layouts and primarily dictate the arrangement of the ceiling grids? If so, what methods have you used to coordinate this?
As as side note: If we could Copy/Monitor Ceilings, this would be a whole lot easier...
Does anyone make regular adjustments to their ceiling grid to cater to an electrical engineer's lighting design? And I mean an 'outside' electrical engineer, not an in-house one.
Thanks.
This is my idea, for this scenario.
Considering that.... :
Also, considering that... :
Therefore, my proposed solution is this:
In the architect's office:
Thanks, Alfredo, that's an idea. However, when a lighting fixture is constrained to the model lines of the hatch, modifying the grid does not honor these constraints, and will require them to be broken. We're aiming to maintain the functionality of the true ceiling grid.
I tested this in RMEP 2012. If you happen to test it and get different results (i.e., elements move with the grid pattern), let me know. Thanks again.
This is not quite off-topic, but I wish to relate my experiences. I'm the BIM coordinator at an electrical contractor and regularly receive new architect models to link into my electrical project file. I have been down that road many times where I need to place my light fixtures, speakers, etc. according to a linked model's ceiling. Not being able to copy/monitor ceilings was a major problem, so I stopped relying on the ceiling. The last project had over 50 rooms and 3 separate corridors and I can't tell you how many different ceiling heights there were, but I know using reference planes for ceiling height quickly becomes a congested mess. Instead, I created new level-based families for all the lights, speakers, etc. that I place "in" the ceiling (teach a man to fish...). Now, depending on how quickly I receive information form the architect, I can either reference a PDF with the ceiling heights marked out and change my AFF parameter on the affected devices, or when I receive the new model from the architect I can run through the space with a section view to see where ceilings have changed (it is rare for this architect to actually tell us what ceilings he changed unless it was changed through coordination).
Now for the ceiling grid arrangement, for my job I only need to do an alignment of my lights to the architects lights, but I did try a few things related to what you need. I tried the model hatch pattern filled region which didn't work as you said, but then I skipped the filled region completely and just snapped model lines to the linked ceiling grid, then hide the link ceiling, then aligned and locked my lights to the model lines. Also, the model lines were all dimensioned and locked at 2'. If I pick one line and move in one direction every device and the lines move fine, one direction at a time. Picking 2 perpendicular lines and trying to move both, say east and north, caused constraint issues. I hope this might shed some light.
Hi Alfredo,
It looks like you know a lot about this type of situation and you may be able to help me with my related issue.
I work in an office where we have an Arch file and a MEP file that are linked. We are having issues where the light fixtures and diffusers are not showing on the reflected ceiling plan and require the ceilings to be cut out in those areas. I tried changing the link to "by linked view" and still can't see their fixtures properly. Any idea of what to do to fix this ?
Our workflow, from the Arch side is:
(We place recessed downlights in gyp ceilings on that workset)
(I believe that they circuit to our lights using copy/monitor?)
