Hello friends,
I have a nested casework family (upper cabinets with sink and lower cabinets) I am trying to show on plan, in two different instances in fact:
First to show the upper upper cabinets as such (which is showing correctly):
Second, to show the lower cabinets when cut in another view. Problem is, when I change the view range of the view to cut at a lower level, the lower cabinets are not cutting.
Can anyone assist me with figuring out how to do this?
Thank you!
Change your Nested/Nested Cabinet Visibility Setting for the Geometry . There's no Geometry Visible in Plan/RCP currently.
Base Cabs not cut:
Base Cabs cut:
Currently this is what shows at 2'-0" cut plane:
