Cant see my ceiling
Cant see my ceiling
Message 1 of 20
Cant see my ceiling
I created  a project with a full floor with walls doors etc.and even a ceiling (which i created in my floor plan) and i cant see anything in my ceiling  plan
Replies (19)
Message 2 of 20
TripleM-Dev.net
First check if the viewrange set in you're ceilingplan would include the modelled ceiling.
Use a section to check if the ceiling falls within the range.
And check phase setting, filters etc...
- Michel
Message 3 of 20
It should be above or below the cut plane?
Message 4 of 20
TripleM-Dev.net
If the ceiling is placed at 2600+floor level the cutlevel should be lower, like 2300+
And the view depth should be more like 2700+ or the next level.
- Michel
Message 5 of 20
Did that and still no changes.
Message 6 of 20
TripleM-Dev.net
Ceiling placed at the level of the Ceilingplan? not a level higher or lower?
Checked things like: Category Ceiling on, no view filters etc... (33 STEPS TO FIND STUFF )
Ceiling not blocked by something a floor maybe or Mass, check in a section.
Otherwise share a Image of section/3D or post the file.
Message 7 of 20
lumbera_darwin
Hi @Anonymous ,
Is the ceiling can be seen in the Section View and 3D View?
Message 8 of 20
my ceiling plane is blank I cant see anything. i dont even see the walls that i placed on level one.
Message 9 of 20
Yes i do see the ceiling in a 3D view as well in a section view
Message 10 of 20
Hi@barthbradley   you just helped me with the lighting placement. thanks again!  could you please help out with this one as well?
Message 11 of 20
lumbera_darwin
Hi @Anonymous ,
i would appreciate if you could provide a screenshot or share the revit file for us to check the problem
Message 12 of 20
Lets take a look at the file.
Message 13 of 20
Sure!  @barthbradley@lumbera_darwin please see attached file
Message 14 of 20
TripleM-Dev.net
Set phase of view to "Project Completion" and do a Zoom Extends!
Message 15 of 20
Thank you so much!
Message 16 of 20
Yep, Phasing. You know, @Anonymous , that's one of the 33 @TripleM-Dev.net  posted earlier.
Message 17 of 20
lumbera_darwin
Hi @Anonymous ,
Are you planning to use all of these Phases? If not, then leave only one Phase (e.g. Project Completion) to prevent you for encountering those issues again.
Removing it should be done by selecting the Phase combining it with the Next/Previous phase.
Message 18 of 20
You right!  (i didnt think its a element issue because i didnt see anything in that view)
Message 19 of 20
Merge 'em? Seriously? Looks like someone's work to me?
Message 20 of 20
lumbera_darwin
Hi @barthbradley ,
Yes. It's just merely a suggestion and it seems to me that it came from some sort of Revit template. Anyways it's up @Anonymous. Checking at the model he's just using the project completion phase only.
You know too much information is also a bad thing.
