cant get slope parameter in my family (Revit 2023)
p_lourensen
Message 1 of 10
p_lourensen
hey all,
kinda new revit user here, (6 months)
i got a question, i have a piece for ducting i use on rooftops for ducts to pass through.
now i need to add a slope parameter but i just cant get it to work. the top side is always horizontal but the bottem varies between flat to 45 degrees
all the flanges are adjustable but when i use a slope parameter it stops working, not to mention the alignment that goes out the window.
can anyone help me to say how i should fix it,
or making it usable for me but then i would love to hear how you did it.
any tips on where to learn this stuf is highly appreciated!
thanks in advance,
Patrick
Replies (9)
Message 2 of 10
azad.Nanva
Hoi Patrik,
Do you have R25 or just R23?
Message 3 of 10
p_lourensen
i have R25, But i need the family in R23 to use it in my project.
or the walkthrough in 25, so can incorparate it in 23
Message 4 of 10
azad.Nanva
you have two asks,work your family with faces not levels,right? and change the angle to make the flat model?the first one is easy , I show you:
(view in My Videos)
for another one i should know your revit version.
Message 5 of 10
azad.Nanva
this is not complete. i must more work on it,but if you can use the concept this will be good for you.
(view in My Videos)
Message 6 of 10
p_lourensen
this is a great start, thanks!
as answer for your question i use revit 23 in this project.
is it posible to flip it upside down?
that way i can use the lower part for the slope. the canal stays 90 degrees vertical and the top edge stays horizontal.
and what kind of family do i need to build it i? there are so many different ones to chose from.
and i see your using a formula, do you maybe know where i can find a start guide for those or something.
thanks again for the help!
Message 7 of 10
azad.Nanva
I try Patrick to make it complete ,maybe tomorrow.
Message 8 of 10
azad.Nanva
share a photo or cad file for details.
Message 9 of 10
Simon_Weel
Using parametric angles in a Family is no joy. They always seem to fail when flexing the Family in the Family editor. But every now and then, that same Family _can_ be flexed in the Project without issue. A matter of trial and error....
Message 10 of 10
SteveKStafford
Another way that doesn't involve family editing (except the sweep)...walls, thin roof and wall sweep.
Steve Stafford
