Hey, so i am trying to edit a cabinet that i just pulled from the internet and i want to adjust the depth, but the only problem is that it is locked(greyed out) because it has a formula attached to it. But i cant seem to find how to get the formula to show up in the properties tab, can anybody help? Thanks!
Solved by ToanDN. Go to Solution.
Solved by barthbradley. Go to Solution.
Widen that dialog box. You should see the formula in the formula column.
...ah! Just realized you are in Project. Open the Family itself and check the formula.
