Cannot view cut pattern at wall ope
umut.akparlar
umut.akparlar
I need a section that shows masonry wall with diagonal hatch. I don't have any issues with showing the hatch but there is an ope on that wall and revit cannot view a hatch on that location, I can only get a solid fill. Is there a way to show the masonry wall hatch at the ope location?
Wall opening is technically cutting the wall member and there should be a cut pattern to be expected? Or is there a way to toggle it? Same masonry wall continues behind the ope but ope blocks the surface or fill pattern unexpectedly.
vitorbortoncello
Looks like a surface pattern. You can ajust the surface appearence in many ways (materials, override graphics...)
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
