Squashed Dimension text in truncated section details
phLB628
phLB628
I have dimension text spanning between two areas of a trunkated section detail. When viewed in REVIT LT the text is as expected. When I print the PDF the text becomes very squashed.
Anyone else had this issue and if so, is there a work-around? I can't "un-trunkate" my detail to move the text as I've put a lot of time into the layout and would rather avoid the abortive work of havin to do so....though, as we all know, REVIT loves double-working solutions....
Thanks in advance!
Detail screen grab from REVIT.LT below:
jay_colcombe
Have you tried an alternate PDF Printer?
Does it act the same?
This thread seems to state it could be related to Screen Resolutions?
Solved: Text is printing larger than it appears? - Autodesk Community - Revit Products
Jay Colcombe
Autodesk Certified Instructor
phLB628
That's it! thank you. I as using the Default PDF exporter in REVIT LT. However...how do you change the PDF engine within PDF exporter? I cannot find this option. Printing the PDFs does not carry the same File Naming protocols as publishing...
Than you!
