Text is printing larger than it appears?
GLDevco
Message 1 of 68
GLDevco
After upgrading to 2017, all of my text is printing to (either Adobe PDF, my 24x36 plotter, or smaller printer) a slightly larger size.  (Almost) all of my fonts are Arial, however I am noticing that there is a difference regardless of font.  For example, my Arial 3/32 front is printing not quite at 1/8" - somethign in between.  If text is say, inside of a revision cloud on the screen, it comes out on the PDF/paper overlapping the revision cloud.  I have attempted to print in both vecotr and raster.  No other patterns, line types, etc. appear to be affected.
Sadly I did not try to start printing with 2017 until today (when I need it).
Accepted solutions (4)
Replies (67)
Message 2 of 68
dzanta
it seems like a font mapping issue somewhere.  look at the text type within revit and see what font is being used.  verify this font is the same with the original revit 2016 or older file
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 68
GLDevco
I thought so too... I actually changed the font to something else entirely and then changed it back.  I only use Arial (for all drawings) and Century Gothic (for title block related stuff) and they both are exhibiting the same behavior.  I just changed to another font altogetherm printed it, and it still is ehibiting the same size difference with a different typeset.  Any other thoughts?
I'm on Windfows 10.
Message 4 of 68
GLDevco
Here is a screen cap, not sure how much more info it will give.  To the right is the correct size in Revit and to the left is the incorrect size showing up in Acrobat (same as priting to a printer or plotter as well).
Message 5 of 68
GLDevco
You know the first rule of thumb when something like this goers wrong?  Restart your computer.
I have no idea why it has resumed normal operatio, I shut it down every night.  But please disregard.  Thanks!
Message 6 of 68
adam.m.nelson
So you fixed this by restarting? I'm having the exact same problem after upgrading to 2018, but restarting is not solving the problem. Has anyone figured out a solution? the text changes size when I try and print to print a PDF or a print to a physical printer. Oddly, the text does not change size if I export a jpeg.
Does anyone out there know how to fix this?!?!?
Message 7 of 68
@adam.m.nelson
Your problem is not exactly as his.  His text size only increased slightly from 3/32 to ~1/8.  Yours is like double the size.  Have you tried another PDF printer?
Message 8 of 68
Radish_G
Hi All,
I also having the same problem, I want to submit my shop drawings by this week, and just noticed the problem. If some got the solution please post it asap.
Autodesk please look into it.
 After Print To PDF, same result if plot the drawing (From Revit MEP File -2017.2)
Regards
Radish G
Message 9 of 68
Viveka_CD
Hi @GLDevco
Please install the latest updates/hotfix for Revit 2017 (R2017.2). Please sign in to your desktop app to install updates.
  • Are you accessing Revit from a remote desktop?
  • Did you try changing the font other than arial font and see if you get the same error?
  • Did you try reducing the font size by half and then try printing? This is not a viable workaround, but I just want you to try.
  • Is your windows screen resolution set to 100%  and not 150%?
  • Are you using multiple monitors, if so turn them off before printing.
Let us know if you were able to resolve the issue.
Please mark this response as "Accept as Solution" if it answers your question to help other members seeking similar solutions. Kudos gladly accepted.
Happy to help if you have additional questions!
Message 10 of 68
Afternoon,
Did you manage to fix this issue? Im having the same problem.
Thank you
Message 11 of 68
Viveka_CD
Hi @Anonymous @GLDevco @adam.m.nelson @Radish_G
We wanted to check back in with you on your posts. We would be happy to take a look and troubleshoot further, if you would like to post a sample file.
I can share a private folder if you like.
Thank you and we look forward to your reply update.
Message 12 of 68
adam.m.nelson
I just reopened the file after being closed for a few weeks and it appears the problem has fixed itself. I will reach out if it happens again.
Thanks for contacting me.
Message 13 of 68
Viveka_CD
Hi @adam.m.nelson
Thanks for letting us know!
Awesome! Good to know that the issue has been resolved.Smiley Happy
Can you check your Autodesk app and see if the recent updates have been installed?
Do let us know if additional help is required.
Message 14 of 68
adam.m.nelson
As soon as I told you it was fixed, it stopped working. I have attached what plots vs. what I see on my screen prior to plotting. Any help would be great. I can't share this with clients.
[cid:image001.jpg@01D3017B.55285C70]
Message 15 of 68
adam.m.nelson
Message 16 of 68
Viveka_CD
Hi @adam.m.nelson
Can you please resend the image and also send us a journal file?
Message 17 of 68
adam.m.nelson
Viveka,
I tried sending you these items, but just got a note saying this was not posted.
Message 18 of 68
Viveka_CD
Hi @adam.m.nelson
I have emailed you a folder to upload the files.
Please let me know if are able to upload the files here.
Viveka
Message 19 of 68
adam.m.nelson
Did you get this figured out yet?
Message 20 of 68
Viveka_CD
Hi @adam.m.nelson
I see that the file is not yet uploaded to the folder that was shared with you. Please send me alternate email to send the link to.
Can you also send us a journal file?
See HERE for a related article on Incorrect tracking of all fonts in Revit PDF's.
Looking forward to your reply update.
