Cannot Upload To Cloud
Message 1 of 21
Good morning, I am continually having trouble uploading scenes to render in the cloud. I posted this a while back but never got a response. In 3 months I have never successfully uploaded once to the cloud. Attached is a screensnip of the error message I always get. Help is appreciated!!!Capture.JPG
Replies (20)
Message 2 of 21
KyleB_Autodesk
Sounds like you need to apply the POODLE hotfix.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Message 3 of 21
That does not seem to work. I tried downloading the 2015 32-bit version and both the 2015 64-bit and R2 64-bit versions and all of them gave me this error message...
I am using 2015...
Message 4 of 21
KyleB_Autodesk
Can you please confirm the build of Revit you have installed?
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 5 of 21
I guess I am confused now. Why does it say 2014 when I clearly have 2015?
Message 6 of 21
KyleB_Autodesk
I can see how this is a bit confusing, I'll try and clear it up -> It is because the build you have installed was "built" on September 5th, 2014.  It comes from the Revit 2015 code branch, I can assure you of that.  We brand our releases in the Autodesk fiscal year they are released, which is typically 1 year later than the calendar year.  Kind of like car companies...
Based on the screen grab, installing the latest Revit LT 2015 update release should fix the communication issue you are seeing.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 7 of 21
That makes sense.... The issue I am having now is the Revit LT update seems to be taking an extrememly long time. When I clicked Install I got this message after about a half-hour...
Next I tried Download All Files and I have had this downloading screen for going on an hour and a half.
Any ideas or just keep waiting?
Message 8 of 21
matthew.d
Hi @Anonymous,
Could you try disabling your antivirus software when installing the update and making sure Revit is completely shutdown prior to install?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Message 9 of 21
Hello... I disabled my anti-virus and had Revit completely shut down. It did install the update this time, however I still cannot upload to the cloud for rendering. Same Authentication Error message as I posted at the beginning of this thread, which is the same message I have got for months.
Message 10 of 21
KyleB_Autodesk
Darn.  I thought that should have fixed it for you.  Here are 2 more troubleshooting steps:
  1. Can you post a journal file from the Revit session when the command fails?
  2. Can you log into the Render Gallery with your Autodesk ID?
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 11 of 21
I can access my Render Gallery and this is what I see...
However, I cannot locate the Journal. In the main AutoDesk folder this is what I see, and there are no folders called Journal inside any of these. Also when I do a search within AutoDesk it says "No Items Match Your Search."
Message 12 of 21
KyleB_Autodesk
Successfuly logging into the render gallery isolates the problem to Revit, good to confirm.
As for the Journal, you appear to be looking in the the wrong location.
  1. Open Windows Explorer (Win Key + E)
  2. Copy-paste the text inside the quotes into the Address Bar -> "%LOCALAPPDATA%\Autodesk\Revit\Autodesk Revit 2015\Journals"
  3. The timestamp is when you closed the Revit session.  Grab a journal from a Revit session where you had the cloud rendering failure.
  4. Attach it to the forum.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 13 of 21
Followed your instructions and this is what I see...
Does my original issue have something to do with the fact that Revit is not listed as one of the supported products in my Render Gallery?
Message 14 of 21
Anybody out there who can take a crack at helping me with this? Please?!
Message 15 of 21
KyleB_Autodesk
There's not much more we can do without looking at your Journal files, which you are having trouble locating. This document exists to help you locate Jorunals.  If you cannot follow the instructions I'm not really sure what else we can do to help.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 16 of 21
First of all, don't tell me I don't know how to follow instructions.
As you can see in the last screenshot I posted, I opened Windows Explorer (as you said), posted the link in the address bar (as you said) copying-pasting the text inside the quotes (as you said). Thus I posted the error message I received in hopes of find help to determine if I am doing something wrong, or if there is a new issue with Journal not being there.
Also, as I mentioned before, Revit does not show in my Render Gallery as a Supported Product. Could that be what the issue is?
Message 17 of 21
KyleB_Autodesk
  1. I assumed you would do some sleuthing around the file system to determine if the journals were in a different location.  A search of "journal" might be a good place to start. When you look in the Autodesk folder of your user app data - %LOCALAPPDATA%\Autodesk\ - what do you see?  Is there a Revit folder?  If so, is there a Revit folder in there?  It's probably called "Revit LT".
  2. When you go to the MyAccounts portal, do you see "Rendering" in your services list?
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 18 of 21
I apologize for losing my temper earlier, it's been a crappy day but I should not have acted the way I did...
Yes, I had done some poking around looking for the Journal, but apparently not enough as I found it only when searching %LOCALAPPDATA%\Autodesk\ with nothing after it, and yes it is in Revit then Revit LT. I have attached the most recent one for you.
Also, yes Rendering is listed with my included Services - however it does not show up in supported files in my Rendering Gallery, only AutoCAD and Fusion do.
Message 19 of 21
KyleB_Autodesk
No worries on the temper.  I've had enough bad days myself to not take it personally when somebody else has one.
I took a look at the Journal file - glad you tracked it down - and Revit progresses past the authorization call, so we can discount an entitlement issue as the point of failure.
It appears to be failing at the point of transferring the scene to the Cloud Rendering service, which indicates the network conditions of the machine are somehow preventing the transfer of the data.  Since we've ensured your machine has the POODLE patch - included in Revit 2015 UR8 - we can discount that as well.  This leaves the firewall as the likely culprit.
This document captures the network conditions that need to exist to transact with our A360 services.  I'd recommend you send it to your IT staff and see if they can verify thise conditions are accessible.  The simplest way to prove it out is to try the cloud rendering in another network environment.  If you have a laptop, it's a matter of connecting it to another WiFi network outside your company.  If it's a Desktop Workstation hardwired to your Ethernet, then that's a bit more of a challenge.
Unfortunately the process of debugging firewalls is not trivial, so hopefully you have a resource available to help you out with the process.  If that's not the case, we can get a support request going to try and resolve.  I feel like I owe you a beer after all these steps...
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 20 of 21
I appreciate the insight... I am a one-man startup, so unfortunately my IT department consists of me and (lately) you!!
The only station I have is a desktop PC that was purchased in February specifically to handle my AutoDesk software. It is on wi-fi, but admittedly I have had numerous issues with connectivity since specifically purchasing this PC. I could purchase a longer ethernet cord to try to stretch to the tower, or possibly have Windstream come re-route my modem to the office rather than the living room. The only other devices I have are an Android tablet and phone.
How do I open up a support request to navigate through this? My only other idea was Geek Squad, but I doubt they would be too helpful when it comes to AutoDesk?
