cannot see level head in 3D view
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i have a 3D view, and when i click the level, i see the level head. but it does appears if the level isn't selected.
It is the same head as in section views (those work). visibility of levels is enabled.
the view is cropped, so the level extends outside the visible region. it seems 3D view level heads don't have the 2D/3D feature where you can move the head in 2D mode without changing the actual 3D level extent (I don't want to change the level extents, but want to change the 2D annotation). Is this a weird limitation in Revit, or is there a trick?
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
