cannot print image on title blk
Hi
I cant print image on title blk to PDF.
Print is set to raster processing but doesnt work.
Pls help
Hi arch7,
Would you happen to know if the image was rotated after being placed onto the titleblock?
Not related to you question but I wouldn't use Raster output unless it forces you too (for shaded, rendered views). Raster images should print fine under Vector output.
Yes, I’ve inserted Jpeg company logo at title blk but image missing when print to PDF. I’m using Foxit Phantom PDF printer. But solved when I change to CutePDF printer. But I dont understand why Foxit cant do the job.
