Hello everybody.
We have several projects that strated a while ago. Since the start of these project we have made several changes in schedules in our template. Is there a way to update the schedules in the running projects to the latest version as in our template?
When we use insert views from file to update them Revit automatically ads a number behiond the schedule name because it is already in the project.
Thanks in advance
Hello Jelmar,
There are some way to do this, but the way that always works for me is:
1). Open the project with the old schedules.
2). Open a new project with the new schedules, in the same Revit window.
3). Go to the "old" project and select the schedules, and just press delete.
4). Go to the "new" project and select the schedules, and press ctrl+c (copy).
5). Go to the "old" project and go to a view (not a schedule view) and press ctrl+v (paste).
Now the schedules are added with the names from the new project and settings from the new project.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Thanks! But I forgot to mention that our Schedules are placed on sheets along with a view that filters out the object that are mentioned in the schedule. So actually that is the problem. Is trhere any solution to export schedule along with a view?
Template doesn't affect sorting and grouping, filters, formula's etc., just appearance. So this is not a solution right?
We misunderstood but this again is no solution. This is how we do it at the moment but its too time consuming. Any suggestions for add-ins that can export Schedules along with views. Perhaps Navisworks is of some use?
Looking on the Autodesk App Store, I found 83 Revit add-ins when searching for "Schedule". If you have not already looked through these, I would suggest checking if any of these will allow the workflow you are looking for.
If none of the existing add-ins will do what you want, you could post a request to the following Ideas page:
If you are looking for a change in how Revit currently works (e.g. option to replace schedules when pasting with the same name as existing ones) you can post your ideas to the following page:
