Cannot Hide Fire Rated Wall from Linked Model
ksmithVURCW
ksmithVURCW
I am working on Interiors with a linked model from the Architect. I went through Visibility/Graphics Overrides (using our own view template) and turned off all the red dashed lines indicating the wall fire ratings. However there is one wall that I cannot seem to turn off the fire rating lines for.
I have gone through what feels like every Visibility/Graphics Overrides tab but cannot figure out how to hide it.
Is there something I am missing? (Am I misidentifying the wall/graphics in some way?)
Thank you
TAB-Select and Hide in View by Element?
ksmithVURCW
Unfortunately, that just hides the entire wall. (I want to keep the wall, but hide the red fire rating line).
Set the Link Display to Custom, then go to the Link Display Model tab and turn off Walls cut pattern.
Sounds like the Architect put that line work for that one wall in Parent Category, whereas the others have that linework in a Subcategory.  If so, why don't you correct it before Linking?
...or open the Link Project directly and see what's really going on?
BrianKellyJHK
Observer
Observer
WORKED PERFECTLY, THANKS!
