Cannot enable "snap" for imported PDF in R2020
HVAC-Novice
Mentor Mentor
HVAC-Novice
I have PDF imported to use a tracing background. The check box for the "enable snap" feature is grayed out.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Because it is a raster, not a vector PDF?
HVAC-Novice
You are correct, this PDF is scanned from a paper plan.
I tried with a PDF that I had generated with Revit (Vector Processing) and it "un-grays" that check mark and I can trace by "picking lines".
Assuming most older plans are scanned, this won't really help me. The scanned copies are not perfect anyway (rotated by 0.347° etc.). So I guess I will have to just manually trace.
Thanks for your help.
DDD-Greg
I am also having the same issue not being able to enable snaps for a pdf file in Revit 2020. I am following a training video where the trainer imports a raster door image from a website and he is able to enable snaps and then scale. Not sure why I can't as I have used the same file from the same website. Still snaps are grey'ed out? Any Ideas? thanks Greg D.
nabo_raymond
Community Visitor
Community Visitor
Hello
I've watched some videos on youtube where they have able to snap a "RASTER IMAGE"
