Cannot create parts for roof in Revit
Message 1 of 23
Hello!
I'm actually doing some details drawings in revit so I have used the Parts for the presentation's poster in my floors, when I came to use it again in my roof I just couldn't use the command, when I go to the create panel I have them all active except the create part I can't use it!
it actually happened before but I did slove it by just undo then copying the view and redo it again so it worked couble of times when I came to the roof it never worked.
anyone knows why?
thanks in adavance.
title renamed for clarity by @Viveka_CD
New title: Cannot create parts for roof in Revit
Replies (22)
Message 2 of 23
You mean Create Parts grayed out? Usually that means it's already in parts.  Toggle Parts Visibility under view Properties to "Parts" and verify.
Message 3 of 23
You cannot create parts from an assembly roof with more than one sloped plane.
Message 4 of 23
Viveka_CD
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community! Smiley Happy
If you create your roof as a Mass, load it into your project, add roof by face, you will be able to create Parts from the roofs by face.
Can you post your roof model and a screencast of what you are trying to achieve?
looking forward to hearing from you.
Message 5 of 23
Right that's what I mean, and I tried the "parts visibility" didn't work it seems like the roof still not divided.
Message 6 of 23
That might be the reason then! so nothing will be used instead?
Message 7 of 23
I think @ToanDN read you right. I didn't. Sorry.
Message 8 of 23
@Viveka_CD wrote:
Hi @Anonymous
Hi, Yeah I am thank you for your kindness 🙂
so I just used a basic roof not a mass. and sure here I attached the 1st screen shot is the roof that I'm trying to work on. and in the second is what I was planing to do it like.
I really appreciate it. thanks
Message 9 of 23
Oh don't be please, thanks anyways I really appreciate your help.
Message 10 of 23
Welcome  to the community, @Anonymous. Sincererly! Glad to have you aboard!
Message 11 of 23
It also happened to a normal floor and I really have no ıdea why almost checked everythıng I know and compared ıt to other floors that ı have done ın the same way but there ıs no dıfference! 3.jpg3.jpg
Message 12 of 23
Variable thickness?
Message 13 of 23
Viveka_CD
Hi @Anonymous
Please share a screencast of what you have tried so far.
Message 14 of 23
Workset that is not editable?
Message 15 of 23
Did you modify sub-elements of the floor by any chance?
Message 16 of 23
I was thinking that too, 404 ERROR (Smiley Wink), but the "Reset Shape" is grayed out.
Message 17 of 23
Good catch.
Message 18 of 23
Sorry for the late reply I was out of the office. Just got the chance to reply, It didn't change much of what I did I already submitted the presentation in this shape most of them were done only the roof part was done just in a section box couldn't do it.
and about the other floors since it was a 10 floor building once it gets greyed out, I used a diffrenet floor and got to try if it works or not so yeah It worked. 4.png4.png
Message 19 of 23
I just checked in case if I did but no I haven't.
Message 20 of 23
@Anonymous: I see you got it to work. What fixed it?
