Unable to associate family parameter to nested family
Kimtaurus
Advisor Advisor
Kimtaurus
I've run into something odd.
I'm creating furniture combinations consitiong of chairs and tables.
For the chairs, I'm able to associate a material family parameter to it's existing parameters (family parameter, type).
For the table however it's not possible. Those parameters are family parameters (I've tried with shared but it's no difference). I already deleted the existing material parameters in the table family, but when I recreate them and reload the family I still can't associate a parameter.
Table parametersTable parametersChair parametersChair parameters
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
ennujozlagam
hello, check if  this is acceptable to you. just trial test. thanks
Kimtaurus
Setting the material parameters as Instance works.
But I'd still like to know the cause of this behaviour.
FAIR59
The table is a shared Family. Type parameters of a shared family are designed to be set in the project, so you can't associate them in the family.
