Cannot Create Ceilings In RCP After Creating Beams?
Initially creating ceilings (by "Automatic Ceiling") worked. The boundaries of rooms were highlighted as I hovered over them and I was able to make one test ceiling. I then went on to make beams (and beam systems) in 3D view (setting camera angle to top). Now back on my RCP, ceilings do not show, nor are room edges highlighted when I try making a ceiling by "automatic ceiling". It appears to highlight the whole building in red when trying automatic ceiling--the rooms are not bounded in a purple line as they were before (refer to attached Image 1).
I have not altered anything: the view range is the same as it was before (refer to attached Image 2), the view template is set to "architectural reflected ceiling plan", there's no hidden ceilings and view settings allow for ceiling objects (just not structural framing).
Note:
-I have tried making the ceiling at various heights--none of them show.
-Working on a Level 11 set to 0'; there is a Mezzanine at 8'7". The U/S of Level 12 is 16'.
Thank you in advance for any insight/help you can provide!
