Cannot control Elevation of an object - disappearing parameter
danezeq
Message 1 of 30
danezeq
i cannot find the "Elevation" parameter in the Famitly types window (inside family editor), thus i cannot schedule it.
Besides, Why does shedule fields window dont allow to add Elevation field? is it beacuse it's instance parameter and not type parameter?
this is the missing parameter:
https://www.youtube.com/watch?v=4DQH1ygJ6Ag
Elevation missing from schedules propeties window screenshot:
Replies (29)
Message 21 of 30
RDAOU
Download dynamo?
Message 22 of 30
danezeq
How do you lock the bottom grip to the level?
Message 23 of 30
danezeq
i use dynamo on a partner's laptop, i have no idea about how it works. it's the first time to even open it.
Edit: i've now opend your dyn file on my pc - and it works well. the thing is it dynamo 2020
Message 24 of 30
danezeq
The project guys, they still work with revit 2019 - it's dynamo 1.3
i have to comply
Message 25 of 30
RDAOU
You can download 2.01 from dynamobim.org
But it's an easy startup exercise for u to do in 1.3
- With the project open...
- start dynamo from the manage tab and make new....
- on the menu open packages (has a search bar)
- type the name shown on the nodes I gave u 1 after the other
- then connect them to each other by click the out arrow on the node and then the in arrow on the next
Message 26 of 30
danezeq
i used your dynamo file.
The purpose of that dynomo thing wat to make a connection between Elevation parameter to "Elevation from level" parameter so it can be shedulable right? Beacuse as you can see, they're still not connected.
is it beacuse of the this warnning in dynamo?
https://www.youtube.com/watch?v=UBgNjOzYM10
Message 27 of 30
danezeq
I think i get the idea now: the dynamo script should be run every time i want to fill in the elevation column in the schedules by the right values.
it wont be updated "live" like a normal parameter. i thought it's just a permanent fix.
Message 28 of 30
Message 29 of 30
Drag the bottom grip to the level and lock it in an elevation view.
Message 30 of 30
danezeq
ohh i see. it works on elevation mode.
luckily, i wont have to do it again in 2020 version and above. so this 2 workabounds are temporary.
THANKS 🙂
