Cannot change rafter cut in Revit Lt
1 REPLY 1
833 Views, 1 Reply
Hi
I'm trying to edit a dual pitch roof eaves rafter cut. When I click the down arrow next to plumb cut it does not drop down & I'm stuck on plumb cut.
Nor can i change from truss to rafter
I've also trying cutting back the lower roof layers (insulation & plasterboard) to stop at the inside wall face using cut geometry... https://www.youtube.com/watch?v=W_rA2i5cnKM
I select the roof, then it asks me to select family instance to cut with? What does that mean?
Appreciate any help?
Steph
1 REPLY 1
The 1st issue I have solved having read other forums, it's to to with my screen settings. I'm using a monitor linked to my laptop. The monitor screen needs to be set at 100% zoom (not the standard 125%). The drop downs now work in the properties box on the monitor screen
Still trying to cut my roof layers back though.
