Can you put dimensions between model lines?
Message 1 of 8
I drew my setback lines with Model Lines, and I tried to put dimensions on them.
Does dimension command not work with Model Lines?
Does it only work with Detail Lines?
Replies (7)
Message 2 of 8
hmunsell
dimensions diffidently work with model lines. Are you sure the dimensions are not turned off in the view settings? try picking the Reveal Hidden option....
Howard Munsell
Message 3 of 8
Are you sure you are dimensioning on a work plane parallel to the work plane that the Model Line was drawn on?
Message 4 of 8
Thank you for letting me know that dimensions work with model lines.
I drew my model line again and the dimension command worked. Thank you!
Message 5 of 8
Woah.... Um.... What does that mean?!
How do I check that?
Message 6 of 8
I thought about your comment. I understand. But I wouldn't question the work plane since they are all being drawn my "site plan" floor.
Message 7 of 8
Actually it was badly worded. I'm envisioning you trying to dimension between parallel lines and your dimension won't snap to one or both of them, so I was asking if you were sure the lines are not "skewed" to the view.
Slightly off axis:
Message 8 of 8
FWIW:
Site Plan View.  Two Model Lines seemingly the same length, yet not.
Both drawn in Site Plan, but on different Work Planes.
...Catch my Vegas act. I levitate things too.
