Can you making contrete cover tangible?
m_blaess
m_blaess
is there a function that makes the concrete cover (Function: Engineering>Reinforcement>Cover) tangible? This would significantly speed up moving or changing existing reinforcement along the green dashed lines. Until now I have drawn normal lines for help.
Many thanks in advance for your help.
Best regards,
Max
Why don't you enter an offset distance on Options Bar?
m_blaess
I´ve allways used this method, but with this one you have to first draw a line on the outlines of the component. So wouldn't it be easier to just use the existing green dashed line?
anze.kumar
Create a reference plane or Line that is locked with dimension of the concrete cover to the edge of the element. than you can draw it on the outline. If you element moves, the reference plane also moves as it is locked
handjonathan
Hi @m_blaess
Thanks a lot for posting your question to the forums!   Has the solution suggested by @anze.kumar & @barthbradley  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
