Can you make different drafting view callouts for the same detail?
gnarkill283
gnarkill283
I have a detail which I'd like to call out on my sections. I would like the callout to have 4 notes: one that has nothing, one that says TYP., one that says SIM., and one that says SIM. OPP. When I try to duplicate drafting view properties and add this info to the reference label value, it changes all the other callouts referencing that detail to the new one. How can I keep them separate? Thanks.
You cannot. If the reference callouts point to the same view then they will use whatever callout type associated with that view. Add those TYP. SIM. OPP. as text next to the callouts.
RDAOU
@gnarkill283
The same callout is TYPICAL, SIMILAR AND OPPOSITE HAND at the same time?! how does that work? Usually it is either or!
The reason they are all changing is due to the fact that reference label is a view/type property and not instance, hence all callouts referencing the same view will receive the same label...One way around that is using dummy callouts
martijn_pater
Similar and Opposite happens a lot. All three maybe not so much.
