Can you change the global visibility of a nested detail item?
kevincoffey
Message 1 of 23
kevincoffey
All,
I am currently trying to achieve the following:
  • I have a detail family of a red dot (filled region)
  • This is nested into a door family
  • The door family is placed in the main model
What I want is for two plan views in the main model:
  • The regular plan with no dots
  • Another 'diagram' plan with the dots showing
I have tried using subcategories - this works perfectly with annotation items (e.g. lines) but doesn't work with detail families.
I have tried using yes/no parameters but this would require turning them on/off on an instance basis across each view and using a view filter.
Am I missing something or is this just a limitation?
Thanks!
Replies (22)
Message 21 of 23
kevincoffey
Chris,
I think that Revit works well with tags and parameters alright. My issue (and possibly similar with Keith) is that a whole set of drawings that we normally produce with colours on them for clarity, e.g. drawings to fire officer or to clients. Perhaps we need to shift away from this but I feel Revit is very close to the functionality that I want.
Message 22 of 23
Here is another approach using colorful Door Tags and Schedule.
Message 23 of 23
Keith_Wilkinson
Hi Toan,
Many thanks for this - the idea of using Symbols did cross my mind but I was still thinking in terms of Yes/No parameters in the door family so needless to say that didn't work - this however is an interesting approach and one that might be worth pursuing until such times as ADesk further improve the functionality of tags.
The scheudle looks great as well - thanks again for your efforts.
Cheers
K.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
