Can we Import shared parameter in revit template file
chandrakant_arya
chandrakant_arya
Can we Import Shared Parameter from one template to another template?
vitorbortoncello
Yes.
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/25inSqC92qlzFgTJHYtXHA.html
or just browse to the one created and load (.txt file):
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
azad.Nanva
yes, use Transfer Project Standarts in Manage :
look at attachment:
Are you asking if you can Transfer PROJECT Parameters that were created from SHARED Parameters to another Project. If so, @azad.Nanva is right. Transfer Project Standards. Afterwards, resave Project as Template overwriting the RTE.
