can we change the parameters shown within the project browser
chris.stroudWUD5J
chris.stroudWUD5J
Hi all,
Within the project browser, the sheet names always shows the same 2 parameters; SheetNumber - SheetName.
Is it possible to change what text is displayed in the project browser?
what if I wanted the project browser to display other parameters, for example:
Discipline - CurrentRevision ?
DrawnBy - CheckedBy ?
I know you can change the order and categories and yada yada in the browser organisation - that's not what I'm asking:
Rename it?
hmunsell
for example:
you can create shared parameters for each thing you want to sort by, then create project parameters using the shared parameters you created. assign the parameters to Sheet or View category depending on where your sorting. the parameter will show up in the project browser sorting options.
Howard Munsell
Mohamed-Nassar
there are some parameters is fixed in revit you can't change them but for sure u can create a project parameter and shared parameters it's very useful for your case, hope i answered ur question as needed if u need any clarification write in comments
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
RobDraw
But browser organization is exactly what you are asking about. That is where the sheet number and name belong in the browser organization.
How about you show us how you would your browser organization to look and yada yada yada...?
Rob
