Can we adjust the vertical spacing of the data lines in a schedule?
Can we adjust the vertical spacing of the data lines in a schedule?  If so how? Whether it has to be done per schedule, globally or individually, I am interested to know how.
Thank You
Nardo
tim_williams077
by default, you can only adjust the horizontal width of a column by selecting and dragging the arrow of each vertical line separating the columns.  If you have content inside a cell that is greater than the width of the column however, the vertical size of the cell will increase to accommodate the content.  For example, a Description column with lots of texts in it will naturally wrap the text if the column is too narrow to fit the text on one line.
