Can two people be the owners of one workset
21 REPLIES 21
Message 1 of 22
AidanHawkins
2305 Views, 21 Replies
I have two work sets - one for furniture and rooms (WS1), and one for everything else about the building (WS2)
Is it possible to have a team work on WS1 and another team work on WS2?
Because at the moment all I can see from tutorial videos is that it is one user that can save a local copy of a workset and own it?
Regards
Aidan
21 REPLIES 21
Message 2 of 22
RSomppi
in reply to: AidanHawkins
Taking ownership of a workset is not something that should be done if more than one person needs to work on it.
Message 3 of 22
AidanHawkins
Then How can I separate the team on WS1 from being able to select elements in WS2?
Message 4 of 22
RSomppi
That shouldn't be necessary.
Message 5 of 22
AidanHawkins
in reply to: RSomppi
The team on WS2 are unfamiliar with Revit and should only be allowed to select and move furniture and rooms
The team on WS1 are savy with Revit and they will look after any changes with the rest of the model, they are totally not concerned with furniture and rooms
How can I separate these two teams? if Worksets is not an option for me
They two teams will need to be able to work on the model at the same time - is this something they need to do on BIM 360 or something?
Message 6 of 22
RSomppi
Separate models. You can't "lock out" users from parts of the model.
Message 7 of 22
AidanHawkins
Okay if they have to be separate models then I will have to do that.. but isnt it a shame that if walls change in the technical model then it will not be updated in the FM model?
How about, when using worksets, I can save the local file to a server rather than ones own laptop - and that way other users will be able to work in that then?
Is that possible?
Message 8 of 22
RSomppi
Forget about using worksets for this.
You should do separate models that are linked to each other.
Message 9 of 22
AidanHawkins
But you cant open and keep saving both models at the same time in that case? They wont be able to use their models at the same time...
Aidan
Message 10 of 22
RSomppi
That is wrong.
Message 11 of 22
AidanHawkins
This is what happens when you open up the two at the one time...
It completely ****s up my model.. rooms go all over the place ect..
So how is this going to work on a regular basis?
Message 12 of 22
RSomppi
You're trying to do it wrong. I don't have time to write out a tutorial but you need something to teach how to do it right.
Message 13 of 22
Yien_Chao
to be able to open related files, you only need to open a different Revit session for each file. but don't forget to sync on one and reload on the other to see the update.
on the main topic: Revit does not allow more than one owner on a workset or element. if your team is able to clearly divide its manipulation area, it is not necessary to own the entire workset. However, inside a workset, many elements can be modified by teammates as long as they are not hosted on another borrowed element previously modified by another colleague.
also tried using options? maybe that could help.
Message 14 of 22
Aside from what have been suggested, you could create a Design Option set with only one Design Option for the WS2 team, with dedicated design option views for them to work on.  That way, they can see the rest of the model halftoned, but cannot select or modify any.
Message 15 of 22
AidanHawkins
Options would be my preferred choice, but does that still mean two users cant open the file and use it at the same time?
Message 16 of 22
Two users can open and use the file simultaneously.
Message 17 of 22
RobDraw
They shouldn't be. That is not what design options are for and you will be making the process unnecessarily complicated for everyone.
Working with linked files is THE way to go. Your experienced users should be able to help you with this. If not, you all need some training as this is a very common workflow. I've used it for the vast majority of projects that I've worked on since I started using Revit in 2009.
Rob
Message 18 of 22
AidanHawkins
in reply to: ToanDN
And this is true that the room boundaries will not start breaking each time the two models are open?
Because this is what happens me
Message 19 of 22
RobDraw
It sounds like you are opening the link while in the project that it's linked to. Just like your initial mistake.
This is a valid workflow. I would suggest that you stop looking for reasons not to use it.
Rob
Message 20 of 22
AidanHawkins
in reply to: RobDraw
I agree - linking the models should be the way to do it.
But, supposedly I cant copy rooms with copy monitor.. it only allows me to use
And it is important that the rooms are linked and can be changed in both models.. Level, Grids (but not multi-segment grids), Columns (but not slanted columns, Wall, Floor, Opening and MEP fixtures...
So I am not looking for excuses I am just looking to see what do I lose if I link the models
