How to use different mullions in one curtain wall?
1 ANTWORT 1
Nachricht 1 von 2
selimfgul
127 Aufrufe, 1 Antwort
How can I use two different mullions in one curtain wall?
1 ANTWORT 1
Nachricht 2 von 2
Mike.FORM
als Antwort auf: selimfgul
Select the mullions you want to change, you will likely have to press TAB a couple times to select the mullion. Unpin the mullion if needed and then change it using the dropdown at the top of properties to change the type.
