Can't select objects in model - in any view, any phase
mpukas
Message 1 of 36
mpukas
I have a building model where suddenly I cannot seelct many of the objects - walls, floors, roofs, doors, windows, generic models, etc. Some objects randomly are selectiable, and many are not. I cannot select them in any view - plan, section, elevation, 3D, or in any pahse.
These pbjects won't highlight when I place the cursor over/on them,and they do not select when dragging a box around/over/through them.
The model was created and is being used in Revit 2015. The project is an existing hsoue with an addition. It appears that the objects that will not slect are in the new construction phase; all existing objects are selectable. And it's not all of the new construction objects, just some of them.
Is the model corrupt? Is my installation corrupt? I am not having this problem in any other models.
Replies (35)
Message 21 of 36
bh-khanh
Hi @Anonymous
Have a good day!
I don't think delete the level is good choice even if is a special level for topo link only. If only you work with that file, maybe don't have any problem, but..... You cannot return if you delete the level, especially it's central data.
it's very high risk way!
Thank you!
BH Khanh
Message 22 of 36
liam.scorer
I understand that this problem will have been resolved by now however, I experienced the same problem but resolved this with a different solution.
 Underlay section within the Properties tab will allow you change the way the Model appears in a Plan View.
It also affects which elements you can select. I found that I could not select (MEP) Elements when Base Level and Top Level are associated to the Floor Levels. See below:
To stop this select None within Range: Base Level options:
This should allow you to select all Elements within the View Range on your View Plan.
Message 23 of 36
cliftonmaggard
This solved my problem as well.  What a crappy default for beginners.
Message 24 of 36
diesellam
I tried all of the suggestions above and none of them worked in my file.  After more investigation and I finally found a solution after checking the properties palette.
It's the discipline that needs to be set to Architectural.  It wasn't set to Architectural initially but the file is coming from the architect (go figure.)
Anyway, once it's set to Architectural and everything can be highlighted again.  See attached snapshot.
Message 25 of 36
md134
Observer
Observer
Thank you so much! This helped
Message 26 of 36
Problem fixed, thanks
Message 27 of 36
m.i.m.o
Now, this is the solution.
Message 28 of 36
kayarash.karami
Big help! Thank you so much
Message 29 of 36
spiro.kalikatzarosMFZ5F
Community Visitor
Community Visitor
Another cause of this is view range bottom/depth
Message 30 of 36
XiaolinHan
Hi every one, I just have ethe same Problem. But it is not about  the Select option on the upper left corner or the under right corner,  it is also not about design option!  I can select all rooms, axises and tags, but cannot select the building part, like concrete wall, flooring and so on.
Does someone have the same problem?
Bests,
Message 31 of 36
vaT58F9
Community Visitor
Community Visitor
Are you kidding me?!!1 I've been struggling with this for like a year and have always just found workarounds to select certain elements. OH MY GOD.
Thank you so much!!!!
Message 32 of 36
vladyacevedoM5GXV
Community Visitor
Community Visitor
When selecting the element in my case columns, you can change the placement either Depth or Height, when selecting Depth you won´t be able to select the element after placed opposite to when you select Height when you are able to select the object after placement.
Message 33 of 36
Thank you for your assistance. For me, the solution did lie in the bottom right hand corner. The non ability to select pinned elements was turned on. Thank you.
Message 34 of 36
mhammesW64C7
Community Visitor
Community Visitor
Thank you VERY much for this information.   This was a huge help!
Message 35 of 36
archpastels
Community Visitor
Community Visitor
hi , its not working. its neither because of design option nor of the arrows in right corner. what else could be the reason.
Message 36 of 36
mbrochtrup
Community Visitor
Community Visitor
Not sure that the issue I was having is the same as those above, but I had been using design options, and accepted my primary option. After I did that I was unable to select the items from that accepted option, and the option set no longer existed in the design option menu. Turns out its a very simple fix, that I hadn't seen online: there is a checkbox in the bottom toolbar, where the workset and design option dropdown boxes are located, that says "Exclude Options" (to the right of the design option toggle). If you uncheck this box it allows you to select those items.
