Can´t select floor
Can´t select floor
compras14E3VX
Can´t select floor
compras14E3VX
Why can't i select floors in floor plan??
arq_42
Check:
- View range (can you see the floor?)
- Is it in a group?
- Select by face
- Select locked elements
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
vitorbortoncello
You need to enable select elements by face.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
compras14E3VX
Select by face worked! thanks
arq_42
You can also move the mouse to the edge of the floor and smack the Tab key.
menuspricesph
Community Visitor
Community Visitor
If you can't select floors in a floor plan view, there are a few common things to check. First, make sure "Select Elements by Face" is enabled this is often the issue when elements are visible but not clickable. You’ll find this option on the toolbar at the top. Also, verify your View Range settings to ensure the floor is actually within the visible cut plane, especially for multi-level projects.
If the floor is part of a group or is locked, that could also prevent selection. Another useful tip: hover your cursor near the edge of the floor and press the Tab key this cycles through selectable elements and can help you grab tricky geometry. These quick checks usually resolve the issue without requiring a thorough investigation.
