Help with specs for PC to run Revit (Mac user)
johannabarge
Observer Observer
johannabarge
Observer
Observer
I am a long time Mac user now needing to use Revit instead of Autocad for projects.
I've done a lot of research on the specs and tried to read recommendations from others on here and elsewhere. I feel like I cannot seem to understand or find a suitable budget model. I will be doing primarily residential work with some rendering but this is the only program I'd use on the PC other than a browser. I do not need a monitor nor accessories as I have those already.
Can someone please link an actual product recommendation that is available in the US? Help the PC world makes no sense to me and I need someone to translate it
mhiserZFHXS
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
Autodesk's recommendations for several builds. "Entry Level" listed at the top. I'm not an IT guy, but spend what you can. I had a Lenovo laptop in grad school that met the requirements but got really bogged down in even basic models. I was never able to identify why.
Others here may have more specific recommendations.
