Can't see studs
Can't see studs
Message 1 of 22
Can't see studs
Hi, I'm just starting out with Revit. I'm just practicing with stud walls. How do I view the studs through the walls? I created the stud under structural framing in the families section. I've tried everything.
Mark
Replies (21)
Message 2 of 22
Can you elaborate on your problem?
Your 3D view shows studs that don't seem to start at the right height - is this what you're referring to?  If so, set the relevant base and top constraints and offsets.
Are you referring to a different view (elevations or plans)?  Note that the actual studs will show in a view when set to fine detail.  At course details you will see lines or symbols.
Message 3 of 22
Hi Tim
I've shown the studs protruding out of the wall to show they are there, they start at the floor level. I want to modify the studs around the door and windows but I can't see them in the 3d view. I've hidden the wall in this view but the studs aren't showing in the wall area.
Message 4 of 22
XXalessio.amodioXX
Message 5 of 22
Are you sure that they start at floor level?  Your 3D view seems to show the studs not starting at floor level.  Try to detach them to see if that helps.
Message 6 of 22
I've tried that XXalessio.amodioXX and it didn't work. I've attached the properties to the section I created
Message 7 of 22
Hi Tim, I've deleted the wall to show the studs
Message 8 of 22
Those show that the studs have the correct top and bottom constraints.  However, attaching them will override these.  Select a stud and type 'HI' which will isolate it - check if it's correct. (type HR to show the other elements again)
Message 9 of 22
OK, didn't see your previous post.  The studs look fine.
Revit won't show the studs through solid objects unless the view is set to wire-frame (or the element has some transparency) - is this what you mean?
Message 10 of 22
XXalessio.amodioXX
Message 11 of 22
I've tried playing with wireframe views and transparancy?
Message 12 of 22
XXalessio.amodioXX
If not working try to design the wall as structural wall and structural column. Your family seems just column
Message 13 of 22
That didn't work, thanks for your help
Message 14 of 22
Ok I'll try that, thanks
Message 15 of 22
I think that whats happening is the studs are constrained by the wall - they are attached to the top of the wall.  When you delete the wall then they revert to the base constraint.  Try hiding your wall (HI) to verify this.
Message 16 of 22
Like this Tim?
Message 17 of 22
Yes, like that.  Try to detach them.
Message 18 of 22
I've tried highlighting the stud and then clicking the Detach/Top Base. It didn't work
Message 19 of 22
Disjoin geometry between the wall and the studs.
Message 20 of 22
That's done it! Phew this has been giving me a headache. Thank you and everyone else - I appreciate it
